No spark need help with honda cr 80!!!!!!
crBoy80
11
i recently purchased a 1986 honda cr 80. it is in good used condition and has a lot of new parts and great compression. i know that it has lost spark b/c it is getting fuel. the guy i bought it from said that it rand good and then just had no spark. i believe i have it wired correctly but do not know what is wrong. Pleas help!
husabutt
203
The first thing to do is a simple test for spark.
Remove your old spark plug
Put a new spark plug in the spark plug cap and lay it against the cylinder so that the threaded part of the plug is touching the cylinder. Use your hand and push the kick start lever down at a fairly rapid pace. Observe the spark plug. It should be producing a nice big fat blue spark. If no spark is present you probably have an eleictrical component failure, loose connection or corroded connection. Make sure the spark plug cap is pressed securly into the wire and the wire securly into the coil.
89kx80
8
Your stater and coil produce the spark,you can take the bike in to a shop and they can test those componants.On an old bike like that chances are the stater is faulty.I do believe they can be rebuilt,but im not sure
overbore
362
check kill switch also as it sends spark to ground and if it goes bad you have
no spark.
The best way to test is just unhook it and see if it runs.If it does then you just
pull the plug wire off to kill it untill you get a new kill switch.
I could give you more ideals,but need to know if you have any spark.
overbore.
