wornknobby
- Feb 5, 2004
- 625
- 0
well, the 86'cr had no compression so i pulled the head and cylinder to find that the piston which took two rings only had one on it and the on that was on it was stuck pushed in. i cleaned every thing up to also find that rod can move from side to side!!!!! this was probally the knocking noise i could hear when i tried to crank it over. But my question is right now as i look at the rod I see two spacers which have some clearance which is why the rod can move, but can i just buy a crank rebuild instead of buying a whole new crankshaft? and if so can some one help to decribe on how to take apart the crank shaft? :ohmy:
