Brandon H.
- Mar 26, 2009
- 199
- 0
So I had bought a 1994 KX 125 a month ago for cheap that needed bottom end work. The bottom rod bearing is bad on it because the rod is hard to turn on the crank by hand with the top end off. With the top end on it doesn't feel any different when pushing the kick by hand, but if u pull the plug and try to turn the kick it fast it makes a clunk clunk cluck sound.
What are my options?? Is it possible that the crank is still good and I can get it split and replace the bearing?? How much does that usualy cost?
I can not find a replacement crank anywhere.
