I installed a O-ring chain for the first time over the weekend. Fun little task to say the least. Once the chain was in place and adjusted, with all hardware tightened. I spun the rear wheel only to find it did not spin as freely as a non O-ring chain. Thinking I may have tightened the rear axel to much, I loosed it and re-tightened once again with a little less torque. Still again, the rear wheel didn't spin as freely as it did with a non O-ring chain. As I was riding yesterday, I didn't notice any real ill effect on acceleration. Is it normal for a O-ring chain to cause the rear wheel to not spin as freely as a non O-ring chain? I know a O-ring chain is heavier and wider. The chain was a snug fit in the chain guide below the swing arm. Could this snug fit be causing this much drag?
Also when I installed the chain I noticed it kinks a little. I figured it would go away after getting some time on it from the first ride. Again, after riding the chain is still kinking some. Is this do to the O-rings in the chain?
Regards,
Sawblade
Regards,
Sawblade
