grass-digger
- Oct 21, 2001
- 184
- 0
hey guys
i have a 85cr250 that i had to dissasemble the bottem end and put a sleeve in the bike, the bike has now stock sise piston inn it before it was 0.075mm over stock i believe anyways since i have had it going again i can't start it at all when hot or cold it needs a jump start its really getting on my nervs i have to run real fast or go down a hill and dump the cluch in first gear and kickstart it at the same time and before i get threw the stroke from the kick start it just wont fire up i have mooved the timing but nothing changed i havent got it to start up with the kickstart it runs fine when rumming except it sometimes wants to rev a bit high kinda of a pigning noise like it was running lean i cheaked my reeds and the are not broken all tho they are not closing completly agains the block anyways i would like to know any tips for what i sould do to try to get my bike going again with the kickstart i have a new carb needle on the way it was cheap and i thought mine might be worn i have dought about this but again it was cheap thanks for any replys
