# of links req'd for a 13-49 sprocket combo?
Clark_W
5
I am going to buy 13-49 sprockets for my 98 KDX and was wondering if the stock 108 link chain is long enough or do I need to go to 110 links.
If anyone has the 13-49 combo and has used either chain length what are your opinions?
Clark
Mac
505
I sometimes run that combo and use 110 Link o-ring chain. If you have a non-oring chain it will stretch more and you may only need 108 links.
I would buy the 110 and remove a link if necessary.
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Mac, that is bad info.
Both the chains will be the same exact size. The non-oring chain does NOT stetch more than the O-ring chain if maintained properly.
Mac
505
I know the chains are the same size when new.
Maybe I wasn't maintaining my chain properly but my stock non-oring chain needed an adjustment every two or three rides. That thing stretched like a rubber band. This continued for a few months until I replaced my chain with an o-ring chain.
I ran most of last season on that o-ring chain and only made two adjustments which is MUCH less stretching than the stocker.
When I ran 13/49 I was using a 110 link o-ring and was on #8 of the snail adjuster, any more stretching and I would have had to remove a link which is why I made the comment in my first post.
