I just popped off the cover of my ypvs on my 1990 yz250, and really old oil came out of there! My guess is that there isn't supposed to be any oil in there. Is that true. If so, where could the oil have came from.??? THanks
I believe your '82 has a totally different type of powervalve. It should have the older cylindrical powervalve which has a lot more surface area and two seals on each side(o-ring and a seal). If you have never had it apart, and there is no oil built up under its' covers, chances are it is(and has been) stuck. The carbon builds up and won't allow anything to pass out of it.
Your '90 has a different setup and may have bad seals for the powervalve.
As far as dissasembly, cleanout and re-assembly, get a manual for your bike and read it. We could give you the idea but I couldn't provide you with details or pictures like the manual can.
I gota 89yz125 and it did the same for me, I pulled out the powervalve and put a new oil seal on it and oring, it still has oil in the area but its significantly less.
