helio lucas
1,020
if you buy a good oil that information should be in the box...
simply because depends on the oil and could be somewhere in the range from 16-1 to 100-1.
most manufacturers recomend a ratio of 20:1 (5%), so if you use the recomended oil by the manufacturer use this, if don't use the recomended by the oil....
and don't look for the minimum values, not allways less oil means more power!!!
Patman
Pantless Wonder
We've been running my son's CR85/102 on Amsoil Dominator mixed at 32:1 in VP C12 fuel for a few years. The bike is properly jetted for this fuel which will make all the difference.
