Thanks a lot to all who replied to my previous post. Jmics was right - the piston/rings hit the powervalve and snapped the top ring which put a large lip on the top part of the piston. (I have pics but I will post those later). Btw, this is a WR250 that smokes, 96 model (same as YZ engine).
The cylinder is perfectly fine, except for a few dings around the bottom part of the exhaust port. They do not extend into the cylinder. This can be filed down/chamfered, yes? It does not look serious.
The powervalve also has fresh ding marks on it, and those don't look serious either. These too can be filed down? I am having problems removing the powervalve. Seems to require a lot of torque with the allen key. More than I can provide.
What could have caused this failure? How can the powervalve hit the piston all of a sudden, out of all this time that I've had the bike running perfectly? The only thing I've done to the powervalve beforehand was remove the left side cover. I recall having problems getting it back on flush, but after some fidgeting it finally went on.
The piston was a Wiseco with an unknown amount of hours on it (but it looked good). I have a new standard size wiseco to put in, and I want to make sure this doesn't happen again. I don't want to end up pushing a heavy bike through desert sand for another few miles. Oh man that was a real workout... :ugg: I had blisters that would put sunny-side up eggs to shame.
Thanks in advance. I'm going to post pictures on here once I figure out how it works. :thumb:
~JuGGz
~JuGGz
