I was browsing the forum and found Luv2Ride had a similar problem to mine yet couldn't determine how he resolved this. I have a 2001 kdx220 that overheats and loses coolant in the radiator during technical riding conditions in cool weather. Back at the bike shop all cooling system checks were performed and passed flawlessly. I tore the top end off and inspected the system for blockage and didn't notice any problems. Circulation appears to be good. It was recommended that I replace the Devol rad guards with the stock ones and try silkolene with water wetter to see if that helps. I've done so and have yet to try this out but I'm still pretty puzzled.
My riding partner has a 2000 kdx200 with the Devol guards and a 50/50 mix. He's never had this problem in the same terrain. In one day of riding with him I had to top off the radiator 3 times.
I noticed that Luv2Ride had the same bike as mine so that made me ponder whether this is a trait of this model or what??? I'm getting to my wits end here. Please help.
Just revving the bike in the driveway and setting the idle high on a cool day with the radiator fully exposed will cause the reservoir to percolate and fill after 5-10 minutes eventually draining coolant (silkolene/water wetter) out the vent tube. I figure this might be normal due to no air flow through the system but could I be wrong?
If it helps, here's what's on the bike:
I'm running a 42 pilot, 1173 needle in 2nd from top and a 150 main below 1000ft, 50-60 degree temp, fairly humid. FMF torque pipe, turbinecore 2, and boyesen reeds are on the bike as well. The plug looks slightly on the rich side.
It's a rainy day in mudville.
