Sounds about right as I got 2106 for my kx5 with dual sport tyres but the best way to measure it is by painting a knobble (just one)and then pushing the bike forward and then measure between the spots that the wet paint leaves on the concrete :)
My enduro computer (pacemaker) is set at 83.25 cm, and it was right on the money at the last enduro. If you can convert the cm to what your looking for, it should get you in the ballpark.
A cirumference of 2146mm yields a tire diameter of 26.9 inches – a reasonable number for a 21” wheel so it sounds like you are in the ballpark. Easy way is to just make a chalk mark on the floor beside the tire, then push the bike forward one tire revolution, make another mark and measure between them.
Handy conversions:
1 inch = 25.4 mm
Circumference = Diameter x PI (PI = 3.1416)
Lorin, what size tires do you have on that thing? (Circumference = 83.25cm = 32.8 inches => Dia: 10.4 inches :eek: )
