SurfinAgain
- Jun 8, 2001
- 12
- 0
My son and I just added some bolt-on mods and did a top end rebuild and they have significantly improved the performance of his '01 RM125.
Here's what we did...
* Added Bills Pipe header and silencer
* Added a V-Force Reed Cage
* Top end rebuild using Wiseco GP piston kit
We are running a 450 jet with the needle in the second clip...this could be a little rich based on Bill's Pipes testing.
This set up has significantly improved horsepower throughout the range but mostly up top were it just rips now. The engine is much more responsive as well. In fact, my son has commented that it feels like a whole new bike and that he's going to have to get use to the new power characteristics.
BTW...for you '01 owners a note on the power valve exhaust linkage rod...ours was broken and had dropped down into the case. This rod is held in by plastic retainers on both ends. The '02 version was modified and is now weld attached on the case end. We purchased the '02 version to retrofit ours so this wouldn't happen. You should do the same to avoid an expensive repair. The new version is $35 and the gasket is $8. If your bike has suddenly lost it's top end power this could be the cause.
