Walt Hollis
- Apr 8, 2002
- 85
- 0
I recently changed out the carb set up to the recommended set up from the popular mx magazines. The magazines had a different needle / jet set up than stock after their test. I felt pretty comfortable doing it since they tested my bike at the same track I ride at. I have a 03 CR 250 and after making the changes it runs a ton better. The only thing that has changed is that I am getting oil discharge out of joint between the pipe and silencer (the lowest point on the exhaust system). I am very happy with the way the bike runs now that I made tha changes. Should I be worried about the oil discharge? If so what is it indicative of?
Thanks, Walt
Thanks, Walt
