pipe springs how to get them on!?!
YZHooligan
23
hey guys
might sound like an easy Q but Ive never done it..how do i attach my springs from the pipe to the cylinder?? jus use some muscle like stretch armstrong?
cheers!
02yz426f
319
long screwdriver will give you the leverage to really move it over to its place. Everytime I use pliers, I end up almost eating away at the hook for as many times as it slips out of my grasp.
mideastrider
827
I use needle nose pliers but if that don't work for you take a wire and loop it around the spring hook take both ends of the wire and wrap it around the shaft of a screwdriver and then just pull like a T-handle. Hook spring remove wire.
76GMC1500
Uhhh...
I take a short length of wire, tie one end off to the spring and the other I wrap around a screwdriver. Then, I just pull the spring on. I use the same process in reverse to remove the spring.
sick 96 250
1,207
vice grips here also, everytime I try to use needle nose or a screw driver I end up losing skin off my knuckles or forearm.
sick 96 250
1,207
What kind of wire are you using, I just cant see how this works easily? I assume you are connecting the wire to the spring at the opposite end of where its going to connect to the head?
Low n Slow
Clutch Cable & Vise Grips
I have a short (12") piece of nice thick clutch cable kinked in the middle such that it folds in half with a tight loop. I run the wire under the spring hook-end, pull it taut and grab both ends up close to the loop... clip the vise grips onto the cables without totally crushing it and I have formed a huge handle that I can easily leverage against the pipe (guarded by my hand) to pull the spring hook clear of the pipe loop. You only have to move the spring about 1/4" to get it off and maybe 1/2" to get it back on.
They make wonderful tools called spring hooks for a reason... they work. I like that the cable method because it gets me right up near the spring and no in-line high tension 6" to 9" away at the spring hook handle from pulling straight out the spring tools provide. My way keeps the drama to a minimum if the spring breaks while under tool tension. That and I just have to do things my way...
