In the process of finishing a top end rebuild on my 2000 kdx 200. When I put one of the new circlips (snap rings) into the side of the piston, I did not line it up so the ring opening didn't coincide with the notch in the edge of the piston pin hole (i.e. the opening and the notch incorrectly line up). No matter how hard I tried, I could not slide it to make it correct. The circlip was put in with minimal compression so it is very tight in the groove. I want to limit the gouging I put in the side already so does anyone see this as a big problem before I button up the top end? Hope I explained my problem clearly. Thanks all.
