freakystyley
- Nov 27, 2006
- 55
- 0
so I finally got around to diggin into the '95 YZ250 I thought had a bad crank bearing. I found the piston to show what looks like powervalve rub - I posted a few pics in my gallery here http://www.dirtrider.net/gallery/browseimages.php?c=3&userid=73918
what I though sounded like a bad bearing might have been piston slap - the piston skirt is worn a lot (67.66mm) on lower back side - may have been the source of my noise?
crank bearing "feels" smooth - slight rub at TDC - but crank is still in the case...rotor/mag and clutch still installed - don't really want to crack it if the top end is to blame. Crank "looks" clean, no burns, no pits, etc. And no debris came from the case after a quick premix flush
what can you tell if anything from these pics?
(other than I suck at taking close up photos!)
