alexb
i hope i can get sum help with my 1996 husky cr250 2 stroke.it hasnt been working lately so i checked the fuel line,air intake and looked at carb.i blasted the main fuel jet inside the carb with an air compressor and it woz blocked.the bike then started and run well but wen turned off and let go cold, it didnt start agen.i think it may be the coil but will a yamaha or suzuki 2stroke 250 coil fit my husky as a husky one is £120! there is fuel getting to the spark plug but maybe the spark isnt strong enough.....? would REALLY appreciate some help..many thanks :)
Probably your carb is still the problem, and you need a new plug. You should get some carb cleaner, remove all the jets, clean all the passages and jets carefully. It is not really a compressed air job, it can blow moisture in it. If your plug fouled it will not spark.
