I was reinstalling my forks after a steering bearing grease job and the lower fork clamp bolt just will not torque to 18 ft lbs. I did the one side of the clamp without any problem and the top of the other side without any problem. However, when I went to torque the lower clamp bolts to specified torque they just kept turning and turning. I suspected I was tightening them past the 18lbs but my torque wrench did indicate so. I just kept tightening, waiting for my torque wrench to say stop, but the clamp bolt snapped. Has anyone had this problem were the clamp bolt just keeps turning and won't reqister torque? Also is it possible I did any damage to the fork or is the metal on the fork hard enough that it is likely I did not do any damage to the fork? It doesn't look like there is any indentation in the fork metal. I am now afraid to use the torque wrench on this bolt again. How critical is the right torque on the lower clamp bolts? This is not a problem with my torque wrench, I tried another torque wrench I had and it did the same thing (wouldn't stop). The pattern I was using to torque the bolts was tightening the top bolt first then the bottom bolt. Is this correct? Anyone know what the size of the clamp bolt is because I will be hunting one tommorrow? Sorry for the long post and thanks for the feedback.
