newfie125
27
hey, i got a 2005 CR125R and shes not getting enough spark to start but when i take the plug out and its wet cause she cuts out and then i can take the plug and and put it right in my ski-doo as soon as i takes them out of my bike my ski-doo will fire them and my bike wont. does anyone think that it may be the coil getting bad.
FoxRocks
51
is it sparking at all?? It could be either your coil, stator or pickup. I don't think these bikes have a CDI to them, but if it does, it could be that. You can check your coil easily with a multimeter, and even your stator...as long as you have the right numbers to know what your looking for. You could start by checking for a short between your coil and ground, and your stator and ground if you don't know what the resistance is suppose to be. I will look in my 99 cr 125 manual and see if it tells me...otherwise call honda and ask them what you should get for resistance readings.
Hope that helps.
~FOX~
newfie125
27
sometimes there is spark and sometimes there is not, but i put a screwdriver in the sparkplug cap and there was no spark going through the screwdriver at all. so me and my dad and his friend thinks that it is the coil. the spark plug is not throwing a good spark at all.
FoxRocks
51
try putting the actual plug in and lay it against the case then kick it over...if there is a weak spark then I would be looking towards your stator assembly (pickup included) just from my limited experiance this sounds like the way to go. I would still check your coil with a multimeter.
FOX
adamant
149
not a raceplug is it ?
