csr
HELP ME PLEASE polini X-1 50 timing
the stator moved i tried to get it back where it was but cannot bike is now a dog,because the timing is off will it run this way i ordered a timing guage i hope this is the onlt problem
Jasle
1,358
depending on which way it moved it can make it a dog. ONly way to tell is to set it up right with the gauge. YOu can make one on your own by taking an old plug and smashing out the insulator. Then put your depth gauged down the center. put a small coffey stirring straw next to it. then epoxy the setup in place. Total cost about $15 if you use a harbor freight dial indicator.
