jaguar
Screwed up the cylinder with a broken piston so I'm going to have it sleeved down here. The machinist can also do a little porting while he's at it. I ride MX once in a great while so I don't want to lose too much off top. But I'd like more mid-range. I have less since the two side valves are epoxied in the open position. The center valve still works. Bike has a Pro-Circuit platinum pipe that really enhances the top end power. I did an experiment to see if lowering the exhaust ports (all 5) would help. I put 1.5mm of epoxy on the ceiling of all 5 ports. It burned out quick but I did notice the upper mid-range gain noticeable power. So at least I'll have him leave an edge/overlap of 1mm on all 5 exhaust ports. (He starts out with an unported sleeve).
Any suggestions from people with porting jobs for more midrange?
