junkjeeps
- Nov 24, 2001
- 671
- 0
What's the best way to clean the powervalve on a CR? I've got the cylinder off for a new piston/rings and the PV is carboned up pretty bad and it's movement is "sticky". Is it easily removeable? Is there any adjustments I would have to make if I pulled it out/reinstalled? I would like to pull it and bead blast it clean. Or is it just as easy to clean in place? One other question - How does the bearing for the PV get it's lubrication?
Mark
Mark
