I have a 95 kx 265 with mo everywhere porting a 12oz. flywheel weight 14/49 stock gearing and a gnarly pipe with a turbine core 2 silencer and the timing is advanced a little but not all the way to the mark. I was wondering if it was normal for the transiton from the low-end torque to the midrange hit should have a flat spot in it. As i'am going through the gears on the road i can really notice it. If i'am in 3rd or 4th and i slowly wind out the gears you notice the low-end torque right off the bottom but then it seems to hit a flat spot for a bit until it runs out the gear a little bit then you feel the midrange kick in all the way through the top end with a pretty smooth transiton. I have noticed this in the woods on high traction areas but not so much in the slippery/loose terrain. Could this be a jetting issue because i have raised the needle one position and it really didn't help just started to spooge a little so i put it back the way it was. This may be normal but i would like to hear from other older kx 250 owners who could give me a little insite. Thanks Vic......... :think:
