I am putting my bike back together for the 1st time, :) I am at a point where I am to put the primary drive gear back on the crank shaft and I have everything ready and waiting, but I'm not sure how to tackle the problem of torquing the bolt to 50ft/lbs without spinning the crank around..
I'm sure there is a tool to buy to do it, but it'd be nice to be able to without spending more for a one time thing
I tried a strap wrench on the gear as I tightened the bolt and it worked until I had to actually put a lot of pressure, then the rubber strap just kept moving/falling off the gear. I dont even think I made it to 30ft/lbs.
Any tricks?
Thank You!
Any tricks?
Thank You!
