I have a PW50 2001
It has had problems in the past, but let just get to the point. the bike runs great without the airfilter on (just the open intake to the carb) the moment i put anything infront of intake it will bog down and stall. carb has been soaked for cleaning, fuel/air mixture has been adjusted to see if it would ruan any bettter, and I even checked to see if reeds are clean of any debris. The cylinder has been changed along with piston. they were both gouged from crap getting inside. when i purchased bike it had no airfilter and housing so i expect that all the damage was caused from no filter. Does anybody have any suggestions. I think it could be in the carb and jetting but not sure
oh and is it true if you take restrictor out at the connection point of exhaust and cylinder that this bike would run faster (better)
thanks
Mike
thanks
Mike
