are you referring to the plug that inserts into the bar? I have Fredette handguards with EE plugs ($9.95) with no problem.
If you are referring to the mounting bracket that attaches to the bar nearest the triple clamps then I did have to bend the hand guard a little to get it to mate up but no big deal. I cut 1/2 inch off each end of my bars too. I used a pipe cutter.
Thanks, and sorry about the confusion. I was referring to the mounting bracket that attaches to the bar nearest the triple clamps.
I'm nearly certain that the Answer Bark Busters, MSR Deflectors, and maybe even the Fredette handguards are made by Enduro Engineering. My MSR Deflectors came with instructions that had Enduro Engineering printed at the top.
