Race gas would be a good idea, but it isn't necessary in a stock motor. You will get less spooge, more consistant jetting, and better throttle response. It will usually require a jetting change. VP C-12 is a good non-oxygenated Race Fuel for 2-stroke motorcycles. This is only basic information however, if you want some more info look for other threads on Race Gas (There are plenty) or do a search on it. Good Luck, I'm sure others will chime in here.
I dont like to run pump gas in my bike, it makes the throttle feel spongy like studboy said. To answer your question race gas wont hurt a stock engine, just help.
It won't hurt it physically, but if improperly jetted, it may even give you worse throttle response than you have now. You may also have fouling issues, etc. You have to jet for it. Plain and simple. If you're going to spend the money on race gas, take the time and learn how to jet the bike for it and you will be happy with the results. Dumping race gas into the tank will not be a magic bullet.
yes to all of the above. if you are going to comit to a full conversion to race gas, you can get a few modifications to the cylinder head to get some more performance for only a small amount of cash. But, once you do this, you cant go back to running pump gas with the modded engine.
yes to all the above plus the term race fuel is rather generic. There is a multitude of different blends. Having the correct blend for your circumstances,jetted correctly can give you a significantly cleaner crisper running bike that is easier to keep well tuned. That should give you a better feel in power and throttle response without having to try and tune out bad gas.
