robwbright
- Apr 8, 2005
- 2,283
- 0
Hello all - long time since I’ve posted - haven’t gotten to ride much this year. . .
Some of you (XRPred, Rich R., etc. . .) aren’t going to believe this, but I’ve joined the 4 stroke revolution.
I recently purchased a 2002 YZ250f - I’d certainly not have purchased a 250f that old . . . except the price was right and the cylinder, head, valves, etc. . . were all recently replaced with new parts.
I got the bike for $1000.00 and sold the RM144 to my bro for $900 - the plastics on the YZF are beat up (got new plastics to install over winter for $80), needs chain and sprockets and new tires, but mechanically seems to be sound.
The bike has a full Yoshimura exhaust, GPR Steering Stabilizer, Tag Metals Triple Clamps, Tag Bars (replaced with my flex bars), suspension by Race Tech (springs also from Race Tech). I figured, what the heck - if the bike gives me a serious problem, I can probably make most of the money back parting it out on ebay.
Pics of before and after new plastics and graphics to come.
Now to the two problems. . .
Took the bike out for first real ride yesterday. 55 degrees outside. The bike will not idle with the choke off unless I turn the idle up really high with choke on - then it will idle semi normal with choke off. However, it seems to sometimes “stick” on a high idle with the choke off.
I assume the carb needs a good cleaning - that’s where I’m going to start. . .
Which leads into the second problem.
My brother and I were woods riding a couple miles from dad’s house. Really slow going, as the woods are pretty tight and the trails hadn’t been ridden much recently by anyone - thus, there were about 3-4 inches of leaves everywhere which made it REALLY slick (it's also been pretty wet here in SE Ohio). The idle was running high (high enough that the bike would continue moving forward significantly without giving it any throttle).
We had just completed a very slow, hilly section - lots of first gear lugging - when my front end began sliding down a slick off camber corner we were on. I kept the bike from falling, but got off and looked down - there was coolant streaming from the bottom of the bike for about 3-4 seconds. Lots of mud, so I couldn’t really see where it came from. I was very concerned that it might have been leaking for awhile and that I might be very low or out of coolant. Let the bike cool a bit, popped the rad cap and couldn’t see any coolant. (When we left the house, the coolant was at the top of the fins, but not all the way up to the cap).
As I was concerned about overheating my new bike, my brother rode back to dad’s and got some coolant. When he returned, I put (guess) less than 6 ounces in the rad and it was topped off. Kicked the bike over a couple times and it was still full. Started it, rode for 5-10 minutes and checked it again - still topped off. Got back to the house, popped the cap - still topped off.
Washed bike, started, rode up and down the street to get it warm, checked level - still topped off. Water pump appears to be working fine.
HOWEVER. . . steam was coming from the right side radiator - and kept coming for 5 minutes till I shut the bike off. Not a lot, but some. Seems to be more close to the cap, but it coming from the bottom as well. Coolant level appears to be staying the same.
I had washed the bike ½ hour before, so I don’t know if there could be “surface water” evaporating.
I’m suspecting the rad cap and/or a very small hole in the rad at the bottom and/or the coolant. The coolant looks VERY green as if it’s 100% antifreeze.
Ideas?
Ideas?
