TrackMaster
- Mar 15, 2001
- 212
- 0
my 96 yz125 is making a loud rattling sound when revved. When it idles it sounds fine, but above 1/2 throttle it rattles and vibrates really bad. Last ride i got armpump really bad and started noticing it vibrating. It is getting progressively worse, and has vibrated my axle nut, sprocket nuts, and pipe mounts loose!
I understand 2 strokes vibrate, but it is getting worse and worse and the rattling sounded like the pipe was loose. After new exhaust orings, tighter springs, and new mounts it still rattles.
The clutch looks fine, it only has 10 hours tops on new crank bearings, new rod, and lower rod bearing. My only ideas are the wrist pin bearing could be shot, and the clutch hub bearing moves just slightly, but seems like normal "play" in a bearing.
