Sounds pretty cool huh? I bet you want one!
I just got this carb from Ron today and installed it. It runs great (at least in the driveway!). I'm trying to make some adjustments and looking for some advice. BTW it has a 40/150 CEL-3 air screw 7/8's.
1. I had to turn the idle screw waaay in (the spring won't compress much more) to get it to idle. Is that normal or can you suggest a possible fix or at least point me in the right direction.
2. It isn't crisp right off the bottom. In second gear at walking speed (this is a test CC has suggested in the past) if I wick the throttle, it sputters then goes. Does that sound like I need to turn the air screw in, or out?
Thanks for the input, I'll let you know how it goes after a weekend ride.
Tom
Tom
