skos
52
REAR SHOCK ABSORBER issues
Just happened. It is as if the rear shock is locked or something. On a 98 YZ125
Last time I rode it, it was fine. Now I have no down force. It goes down about an inch and that? I then can pull it back up but it still does not have full motion.
I pull it apart as best as I could and cleaned/greased, but still have issues.
I most likly will replace the bearings.
What is the trick to getting the bearings out?
Also BOLT #27 in the following link will not come out because it hits the swingarm
http://fiche.ronayers.com/Index.cfm/...Group/REAR_ARM
__________________
skos
52
All fixed! Thanks to Andrew from another forum.
You will need to remove the long swingarm/engine mount bolt that goes right through the frame. Otherwise you can not remove #28 (bolt).
Lay the bike on its side (don’t forget to turn the gas off) with the nut upward and really soak the nut in release fluid. Leave the bike to soak overnight if it has been awhile, meanwhile go find a length of 1/2" diameter brass or aluminum, something soft. You'll need this to drive the shaft out.
All the YZ suspension bushes can be removed using the Motion pro tool and some 2" lengths of 1 1/2" internal diameter tubing. You use this to draw the old bearings out of the swing arm and knuckle joint. Water pipe works just fine. I did not have the tool so I used sockets (I do not recommend) but I needed it fixed ASAP.
I found that there was a lot of dirt in #21 (ARM, RELAY). I have it apart but #22(Bearing) did not seem to move. I good cleaning and greasing and it works fine.
#22(Bearing) should move freely in #21 (ARM, RELAY) If it does not, get the rebuild kit. Also #25(COLLAR) should move freely in #22(Bearing) again If it does not, get the rebuild kit.
Here is the link for the diagram
http://fiche.ronayers.com/Index.cfm...123/Model/YZ125/GroupID/247149/Group/REAR_ARM
I will post a new thread to summarize the process and make it easier for everyone.
