If I go from a 52 tooth rear sprocket to a 48 tooth rear sprocket, which of the following applies:
I do not need to change the chain because the diatmeter is still the same OR
I do need to change the change length.
a smaller tooth rear sprocket will cause the rear tire to spin slower or faster? OR
a larger front sprocket will case the rear tire to spin slower or faster?
Thanks in advance.
Paul
Thanks in advance.
Paul
