This morning i was feeling a little destructive/curious so i took a grinder to my old TS185 expansion chamber that was already destroyed. To my surprise i found that there was enough gores lining and baffling to wrap around the planet, stuck to the inside walls of the chamber, and a plate 3/4 of the way along the pipe with a hole 3.5 centimeters in it restricting about 3/4 of the flow with even more baffle about 15 centimeters worth protruding. Oh and enough carbon and soot to make santa cry :laugh: So yeh i was thinking bout cutting the pipe and tearing out the restrictor contraption but leaving the lining in because its more work and probably make it crazily loud?? Is this some sort of lame attempt by suzuki to make a double chamber or something or is it simply a restrictor? If i do remove it is it going to be a guaranteed improvement to mid to high power but with out it being so pipey its :coocoo: ? Some jetting changes required? Thanks for any help advise you can give me.
