I am trying to replace the fork seals in my TY and have everything apart, including the clip on top of the seals, but can't get the old seals out. HELP!! :(
Try putting the inner tube back in the outer tube, and put the lower bolt back in the fork, and fill the fork full of oil, and then press the inner tube into the outer tube, the oil will hydrolic the seal out.
Works great!! good luck
