Hondaxrguy
573
Ok, I'm trying to remove some ugly purple tint that was on my wife's car when she bought it. I've used a hairdrier to ease the removal, but after peeling the tint off, there's a very thin layer that remained. It looked like it was just some of the adhesive left on the window, but after looking at it from the outside (and later scraping it with a razor blade) it's actually more tint. Is there a secret to removing that stuff? Something that will eat through that thin layer so I can just wipe it off? I've tried Goo Gone, but it doesn't help at all. Thanks.
BTW, the window has one of those defrosters on it, so I need to be careful.
Jeremy
Jeremy
smb_racing
Master of None
2,082
Take a razor blade and slit the tint, then to rub some alcohol over the slits to loosen the adhesive.
a454elk
Mexicutioner
7,529
18
Turn on your rear defroster and heat it up. Make the cuts like smb stated, in between the defroster lines and peal it off, hopefully it will work.
