Renthal Thinwall / Pro Taper set-up?
BJH
126
I want to change my bars over to Renthal Thinwalls or Pro Taper bars as cheaply as possible on my 03' 220R. I want to keep my odometer and leave my self open to using a Scotts or GPR stabilizer in the near future. I'm leaning towards the Renthal set-up because the odometer set-up I've dreamed up has definite wedding kit removal potential if I happen to go over the bars. So the cross bar on the thinwalls looks like the way to go. I would rather not change the upper triple clamp but I will if I have to.
Can I do this just by changing the bar clamps?
If I have to change the the upper clamp will a KX, KLX, CR, etc. clamp work?
I have FRP bark busters and guards. Can I still use them just by changing out the inner bar clamp?
My preffered bend is the CR High.
kdxluver
31
Renthal handlebar mounts
I used some handlebar mounts that I got from Applied Racing.... they work great.... I fell really hard yesterday and all I bent was my new Protapers..... The handlebar mounts are alot cheaper than a new top clamp....
Randy
