My sons KX60 is leaking coolant into the tranny. This seems to be a common problem as everyone had the same solution 'Replace the seal behind the impellor and the problem is fixed. I have the seal and the bearing on order.
Is there any trick to this. I know how to drain the rad. From the outside removing the water pump looks fairly simple. Two screws holding on the water pump. Anybody know what I will find when I remove it? Any exploding, spring retained part that will fall out into my hand with me having no clue how to re-assemble? Will I need any special tools to get to this seal or replace the bearing? Any help would be appreciated.
