Tonight I swapped out my miserable OBDVR needle (CA 520 EXC) for the OCEMN, and installed a 165 main and a 50 pilot.
However, can anyone tell me about the following:
Imagine taking the bowl of the carb off. On one side, pointing up towards the top of the bike, there is a rubber boot/diaphragm about 1/2" long, from which protrudes a rod about .1" in diameter, bent at a 90° angle.
Does the bent portion of that little rod insert into something when you re-assemble the bowl?
I didn't take notice (famous last words) when I pulled the bowl off. I assume it has to do with the accelerator pump, in my limited but growing understanding of FCR carbs.
Also, what is the (jet?) opposite the pilot jet? Aligned in a row are the pilot jet, the main jet, and another jet, which I mistakenly pulled first when attempting to change the pilot. Obviously it was not - it was marked as an 85.
Thanks for any assistance.
Rod
Rod
