uts
305
I have an 86 CR250. It runs really well but fouls plugs after about 3 hours, quicker if I am putting around. The plug is always black and oily. I use Motul 800 2t at 40:1. Not too much spooge with motul, but there is a bit of spooge. I am guessing it's too rich. I had the bore done and the guy said it had a mad porting job, but I don't know what kind of porting. It does seem to have a lot more bottom end power than most 250. The pipe is stock.
My question is do you need to re - jet for a ported cylinder. If so is it usually leaner or richer or does that depend on the kind of porting. Seeing as it runs so well I don't wanna touch it at the moment, but am just curious.
Studboy
Thinks he can ride
Dec 2, 2001
1,818
Try leaning out your pilot jet, it should help with your fouling issues and give you some more response to boot!
uts
305
crazyYammi said:
sounds like a bad crank seal is leaking trans oil into the crankcase
Don't think so.The bottom end is fairly new and no loss of tranny oil. Also not the classic clouds of smoke that you see with this problem. Not much smoke at all really.
Studboy
Thinks he can ride
Dec 2, 2001
1,818
If you are certain that it isn't the crank seal: 1. Check your reeds, 2. Check your float level 3. Try leaning out your pilot jet.
