Running high compression on two stroke
crazyYammi
89
I have been thinking of getting a phathead and playing around with high compression on my yz250. How much benefit do I get out of high compression on a 2stroke? I will be running trick 110 it is 4$ a gallon here.
Dragmeistr
149
I put the VHM head with their motocross dome on my bike, granted it is a completely different engine and bike, but all I can say is that I didn't like it. I guess it depends on what kind of riding you want to do, but it made my bike run very flat up top. The little bit of increase in the bottom was not worth how much I lost up top. The phatheads may be different, I don't know.
Studboy
Thinks he can ride
Dec 2, 2001
1,818
I have also had unsatisfactory experiences with cutting the head for too much compression, it does give a little bit more lowend but it really kills the overrev and makes the bike more susceptible to pinging due to poor fuel quality.
Dragmeistr, I don't know about how your stock CR head is setup, but on my YZ the VHM had a much much wider squishband than the stock head, with a little less overall volume. Squish was set at 1.5mm.
Maybe you can clarify this for me Marcus, what is the advantage of going to such a wide squishband? Why does VHM do it?
youngr51
38
Higher compression usually brings more power but other things have to be takin into consideration like ignition timing, fuel, and mostly reliabilty. Cylinder temps will change as well. I dont think the power will outweigh the headaches. Paying for race gas sucks as well at $5 a gallon.
Dragmeistr
149
I had Eric Gorr redo the dome in my head when he did my cylinder. I am assuming this head will cool better than the stock head is the reason for me using it.
marcusgunby
6,450
A wide squishband tends to give more bottom end but trades for top end,the best head designs are the ktm ones, they are top hat shaped, all the volume is very close to the plug-even though the rm is a copy of the ktm engine its still not as strong, 2 reasons, one the inlet isnt as straight and two-head designs.
Th enew YZ125 is as powerfull as a 03 ktm 125 mainly due to the straighter inlet/exhaust tracts.
bedell99
788
Marcus do you think the CR's can benefit from a different shape head?? I remember looking at a KTM and the head looked very different from my CR.
Erik
steve125
1,252
I think one of the reasons, and there are many :) the cr250 has weak bottom. Is too large a reed cage, low primary compression, and the cylinder port ducts are too large.
Shall I continue??? :) Poor PV design, the wrong carby and poor jetting, improper ign. mapping, and a real heavy crankshaft.
The spark plug is dialed in though :rotfl:
marcusgunby
6,450
bedell99 said:
Marcus do you think the CR's can benefit from a different shape head?? I remember looking at a KTM and the head looked very different from my CR. I wonder if Honda did, what Kawasaki did and copy Yamaha's port design.
Erik
LOL on steves comments,
yes i do think the cr head is a poor design-it looks the opposite to a ktm setup.
WillyM
84
Head Design
If you want to redesign your head get the book from Grahm Belle 2-stroke engine design.
I read that a top hat with a 35 degree squish angle and it needs to be 40 to 60 thousanths from T.D.S.
I did the head on my retro 88 kx 250 and I did a bunch of other like 230 lbs of compression mods and it rocks.
I use vp c12
I am working on the same mods for my 03.
bigguns
8
i have a 2003 kx 250 with a phathead on it and the dome is 2 stages above stock compression. you would not believe the power this sucker makes. i was thinking i would have just low end power, but i was wrong. i have much more power everywhere. daylight and dark differance.
Duane
32
I recently bought a CR 80 bored to 108, and the head has been milled. The seller recomended running race gas. Do I have to run race gas? Will I do damage if I don't?
Studboy
Thinks he can ride
Dec 2, 2001
1,818
If it is setup for race gas, then yes you need to run it or face meltdown.
