helio lucas
1,020
polarisracer242 said:
new motor, CDI, Stator.
that should solve your problem. :think:
if has spark one in a while it will be a 6 stroke, or is 8 stroke? now that you have more strokes than everyone else, you are fast...
step one: replace the spark plug with a new one.
step two: inspect the wireness and all the connectings, including disconnect the kill switch.
step 3: inspect visualy the stator.
if after all this work it wont just ask again in this thread.
Patman
Pantless Wonder
That is a common fail point, the coil is another possible problem but not real common.
helio lucas
1,020
yap :nod:
they just slowing degrades until have no spark or misfiring on peak torque.
a internal rotor kit usully is a very cheap replacement for the entire electrical system. keep in mind that most don´t come with lights generator.
cdi's on those bikes are almost bullet proof.
just don´t look at wireness, inspect it. disconnect all plugs and check for corrosion and shorted cables.
