After about 1hr of riding this past Saturday my 93cr250 seized up going when doing a fairly long run - I was at about 2/3 throttle and jetted on the rich side so still not sure how or why it seized.
Anyhow, all of a sudden the motor started making a 'whining' sound and felt like it was slowing down then a telltale clunk (all of this happened in less than a second). I pulled in the clutch and came to a stop as fast as possible.
A friend and I pulled the cylinder and piston and both look worn but no obvious damage like I would expect from the seize. When the cylinder came off their was a piece of metal - about the 1/4inch circular - sitting on top of the crank.
I have done top ends before but never the bottom. I am worried that splitting the cases is going to be required. The biggest problem I have noticed so far is that when I turn the crank, at the bottom their is about 1/4 inch of vertical play. At the top (TDC) the crank seems to bind up and not want to pivot.
My previous bike was a 90kdx200 which I ended up pouring money into and I really can't afford to do that again. If anybody has any ideas or suggestions I could use the advice.
