SO i went over the bars HARD last weekend landing a step-up and i noticed when I was replacing my front number plate, that the tab on the front of the frame was half-sheared off. (I have a 2003 RM 250)
Has anyone re-welded one on without removing the head tube bearings? I don't have the tool to remove the bottom triple clamp. The tab is not all the way off so I'm going to just ride it for now.
If i do remove the bearings and re-weld the tab on will the head tube likely warp? IT is a big chunk of steel, but I would like to know if anyone has done this before? Let me know is there is a good way to go about it's repair.
Thanks a ton!
Thanks a ton!
