Apr 18, 2007
7
i recently bent my shift shaft while hitting jumps , i had to cut it out of my engine.
i have a spare shift shaft but the top mount is different,
i was wondering if i could use a metal laith to cut the welds then switch the mounts then re weld it to the good shaft.
think it will work?
thanks- steve.
think it will work?
QUOTE]
If the shaft is the same diameter, the same length and has the same splines as the old shaft it will work.
