3 months, weekly? Right on the money for maintenance, depending on use, abuse, and the dreaded power washer. Over doing, can be as bad as not doing. Those bolts get lobed, loctite is not going to help. Water proof grease rules. Vintage BobJoburble said:IMO you should be maintaining your bike regularly enough NOT to use locitite. Torque the bolts up as per manual and check ALL bolts on bike regularly. Strip, clean and regrease every 6 months-ish :nod:
whenfoxforks-ruled said:3 months, weekly? Right on the money for maintenance, depending on use, abuse, and the dreaded power washer. Over doing, can be as bad as not doing. Those bolts get lobed, loctite is not going to help. Water proof grease rules. Vintage Bob
Fatherof2 said:I am using generous amounts of Bel Ray as I put my KDX back together.
Thanks All,
D.
