Gerncrf450r
Installed RT revalve front and rear, good results w/ one exception: I don't have enough adjustment to speed up the rear rebound. It's not WAY off but I'm out of clicks when I should be around mid-range. Given that the shim stacks were from the light side of the chart, I'm thinking installation error. I was thorough w/ the bleeding and made sure the shock shaft had same extension as before. Something I missed w/ the damping adjuster perhaps? 2005 CRF450R, nitr. - 175 psi., sag set 100mm. Any ideas......thanks.
FRESH VIDEO
