K Dixon
Has anyone done a simple bore from 33 to 36mm. Results ?
The RB Mod sounds great but could be a very expensive option for me, sending the carb from Ontario Canada paying exchange and duty, tax and brokerage fees etc.
Robcolo
342
After completely stripping the carb body -- including the needle jet assembly from inside the float bowl [you need a tamper proof torx tool] I clamped mine to milling machine table and bored it out to approx 35.5mm. The stock 220 bore is offcenter from the carb body casting whereas your overbore will be centered, it's lower diameter coinciding with the original bore's OD. In other words all of the metal is removed towards the top of the carb or you screw up the relationship between the needle jet assemblyl and the bore. It now revs as hard as my KX 250. It doesn't appear to have hurt bottom end, but I also milled the head - and this improves bottom.
davidg
193
Have you tried FRP? He doesn't change the jets or work on the slide, just bore the carb. If memory serves me, I believe it's $60. (708)946-0999
