It's easy enough to check. Move the clip up one notch on the needle and then ride the bike to see how you like the change.
You can also try adjusting your air screw if you haven't already fine-tuned it. After you adjust the clip, you should re-tune the air screw before drawing any conclusions.
Good luck.
