The Honda Pilot
- Feb 25, 2001
- 394
- 1
My bike has been sitting for over a year and I went to crank it up...started great I put new fuel and gear oil in it. But I found the throttle turns but is really slow to return back. I stopped the engine and played with the throttle and it was still the same. I would turn the throttle and it wouldnt snap back to closed position it would slowly come back. So I tore into the carb and checked the slide it was clean as could be. Could it be a bad cable in which a new cable would fix the problem ? or could it be a bad throttle barrel or whatever its called that the grip gets glued to??? I think I might try to lube the cable just to see if thats going to fix any of this problem and ideas guys? Anyone had this happen?
