jth said:Stealthy's rotor for E series KDX has 6mm tapered bolts. A 91 250 has 8mm bolts. You most bore out and retaper the new roter, and cut down the heads of your 8mm bolts to clear the hub. Then it will work.
julien_d said:Good info, jth. Sounds kind of like a pain. Didn't Moose Racing use to carry one for H series? I thought so, but didn't find it.
I just went looking for that thread at KDXRider, and once I found it I realized that was your thread. Did you get it on there??
